Novidades Leves
pedro25martins
Travões d'Home, ainda mais leves...
Using the NEW! Mini lever design and existing caliper for 2007 - the brake has shed even more weight from it's previously slimline design through the use of a carbon lever, 12 piece Ti bolt kit and a lightweight version of the floating rotor.
FEATURES OF MONO MINI PRO
*Carbon lever with custom graphics
*Lightweight (1.8mm) floating rotor
*Ti bolts to master cylinder clamp, caliper & bracket mounts and rotor bolts
*Custom etching for master cylinder cap
*Custom colour (gunsmoke) to caliper, master cylinder and connector
*295g overall weight - including ALL parts needed to use!
*£175rrp per brake
Menos 80g que a versão "normal"...
Menos 50g que os Avid Juicy Ultimate...
Alf
Deixo aqui um tópico para postarem as diferentes novidades que vão surgindo no campo dos weight weenies.
Com isto refiro-me a novidades de fábrica, de todas as marcas, e não tunings.
Agora que já lancei o réptil :mrgreen:, deixo aqui algumas com que me vou deparando:
Avanço FSA OS-99 - Peso: 98g
Disponível de 80 a 130mm, +/-6º, oversized apenas, inclui parafusos de titânio.
Pedaleira FSA Kforce Light - 750g
cyclingnews.com said:
The new K-Force Light MTB crankset also gains the '3rd Generation' double-hollow carbon fiber crankarms and hybrid ceramic MegaExo bottom bracket bearings of its road-going cousin for a total claimed weight of 750g.
Agora vá, comecem a postar :D
Vitorzip
Ax-Lightness combination Saddle & Post
110 - 115 g
Please note: This is a very technical and time-consuming product to manufacture correctly. You will need to provide us with your existing AX saddle and current seatpost, in the position you need... A jig is then manufactured around this combination (And your items returned), allowing AX to produce a perfect, lightweight replacement.
Availability: Please expect approx. 12weeks for this item to be produced!
Weight (saddle & post combination): Approx. 110 - 115grams at 27.2 x 250mm
Price: Approx. £490.00 (750€)
OBiklas
ò vitor!! que coisa é essa??? FDS!! feito à medida!! :lol: :lol:
daqui a pouco ainda pedem a largura do traseiro... :mrgreen: :mrgreen:
vá-la que o preço até é convidativo em prol do peso doh
Vitorzip
Não, é uma pipa de massa. Alem disso, a diferença de peso para o conjunto que tenho é pequena, e o selim é igual...
crx16v
Que coisa fantástica!! De sonho, mesmo! Chovera dinheiro e... :mrgreen:
Quanto a troca, não me admiraria muito se o Homem daqui a uns tempos tivesse um par com o nome, novamente, gravado eheheh
Vitorzip
s-works epic -9kg said:
sera k aguentariam umas provas de xc e de maratonas?
Sim, Pedro, aguentam. Ainda por cima com alguem leve como tu. Foram desenhados para XC, e nunca vi nada da Tune dar "barraca" em muitos anos de consumo pessoal...
Silvas
Vamos lá "acordar" este tópico :twisted:
Novo Maxxis Maxxlite285
Peso: 285g
Aperto de espigão de selim MSC Ultralight
Disponivel nas medidas 31.8mm e 34.9mm
Peso: 9g
dealer
estes pneus maxxlite .. muito leves ..
mas a sua durabilidade e baixa certo ?? :wink:
qual o preço de cada pneu ??
P.s- continuem com o topico pois ta bastante interessante :mrgreen:
FábiO*
