também tens a Durin SL de 2010, de 80 mm, a 589€.
O absolute é o sistema similar ao Albert Sl da Magura:
"Absolute
Absolute is a platform-style damper. This means that the fork can be set to remain rigid until a certain impact threshold is exceeded. The benefit is pedaling efficiency. As proponents of rigid forks will attest, suspension has the potential to diminish pedaling efficiency by compressing the fork rather than propelling the bike forward. In the open position, the Absolute damper acts much like TPC, absorbing even slight impacts. By introducing a bit of damping platform, a rider can get the benefit of suspension without the penalty of wasted energy. In the second and third positions, the Absolute damper resists pedal bob and brake dive on smooth terrain, yet still allows the fork to move through its travel over most bumps. In the fourth and fifth positions, the fork remains rigid during most out-of-the-saddle sprints or climbs, at the expense of some harshness over washboard and rooty trails. In the sixth position, the Absolute damper locks out the suspension for everything but a major, abrupt impact, like suddenly running into a rock or log.
Forks equipped with the Absolute damper have a platform adjustment dial on the top of the right leg and a rebound adjustment dial on the bottom of the right leg. The platform adjuster has a total of six positions ranging from completely open (no platform) to completely closed. The dial can be turned from one extreme to the other in about 1/3 of a turn, for easy on-bike adjustment. The effect of the various platform settings is more apparent at speed than when the bike is at rest."
retirado do site da Manitou
estas Manitou têm apenas pernas de 30 mm em comparação por exemplo com as de 32 mm das Magura.
