zecarlosvsc
Gostaria de saber qual, na vossa opinião, destas 3 bicicletas devo comprar.
Scott Sportster 50 Men
Frame: Sportster Alloy 6061 D.B., Integrated headtube, Scott urban kit ready
Fork: Suntour NEX 4110 V4, Susp.fork 1 1/8, 63mm travel, Integr. 700C
Headset: Ritchey OE Logic Zero, semi integrated
Rear Derailleur: Shimano Acera, RD-M 390, 24 Speed
Front Derailleur: Shimano FD-M191, 31.8mm
Shifters: Shimano ST-EF 51 L, 8R, EZ-fire plus
Brake Levers: Scott Comp
Brakes: Scott Comp, V-Brake
Crankset: Shimano FC-M171, 48x38x28 w CG
BB-Set: Shimano BB-UN 26 / 68-113mm
Handlebar: Scott Sportster OS 600mm, 9° bend
Stem: Scott Comp, JD-ST58 A, 31.8mm
Pedals: Wellgo C 127 S
Seatpost: Scott 31.6mm
Seat: Scott Sportster
Front Hub: Scott FM-21FQR
Rear Hub: Shimano FH-RM 30
Chain: KMC Z-7
Cassette: Shimano CS-HG31-8I, 11-32 T
Spokes: Stainless, 14G, 2mm
Rims: Araya GP-722, 700C, 32H, black, CNC
Tires: S207, 700x37C semi-slick
Weight: 13.20 kg / 29.07 lbs
GT Transeo 4.0
Type of Frame
Hydroformed / 6061 Aluminum Frame, Triple Triangle™ Frame Construction, Forged Bottom Bracket, Dropouts, and 1 1/8" Head Tube
Fork
SR NEX4110 w/63mm Travel, QR, coil spring pre-load adjust, fender mounts
Crank
Suntour XCC 48/38/28
Bottom Bracket
Tange Cartridge sealed
Shifters
Shimano EF-51 Rapid Fire 8-speed
Cog Set
Shimano HG-31, 11-32 8-speed
Chain
KMX HG-40, 8-speed
Front Derailleur
Shimano FD-M191
Rear Derailleur
Shimano Acera 8-speed
Rims
Alex ACE-17 Double wall with CNC 32 FR, 32 RR Hole
Front Hub
All Terra Sealed Mech Alum, with QR 32 FR, 32 RR Hole
Rear Hub
Spokes
Stainless Steel 14 G
Tires
Innova Land Tracker with Puncture Guard, 40c, 700c wire
Pedals
GT Nylon trekking
Front Brake
Tektro Direct pull w 70 mm arms
Rear Brake
Brake Levers
Handlebar
GT All Terra Alloy Riser Bar, 640
Stem
GT Alloy Ahead type
Headset
FSA Integrated with cartridge bearings
Saddle
GT All TERRA with Bio-Morphic design
Seat Post
GT All Terra 2 bolt with forged head
Specialized Crosstrail
QUADRO
Alumínio Specialized A1 Premium, soldaduras polidas, pré-instalação para guarda-lamas e porta-bagagens, dropouts forjados, apoio para descanso
FORQUETA
SR Suntour SF11-NVX-700C, jarras de alumínio, pernas de 28mm, mola helicoidal customizada para mulher, 75mm de curso
CAIXA DIRECÇÃO
FSA Ahead, copos 1-1/8" em Cr-Mo forjados a frio, esferas soltas
AVANÇO
Alumínio forjado a quente, 4 parafusos, 20° de inclinação, aperto de 25.4mm
GUIADOR
Elevado em aço Hi-Ten, 640mm de largura, 35mm de elevação, 8° de recuo, 4° de curvatura, 25.4mm
PUNHOS
Specialized Body Geometry XCT, composto duplo, borracha Kraton, extremidades fechadas, 132mm
TRAVÃO DIANTEIRO
V-brake de alumínio fundido, calço de uma só peça
TRAVÃO TRASEIRO
MANETES TRAVÃO
Alumínio V-brake, dois dedos, acção linear
DESVIADOR DIANTEIRO
Shimano FDM-191, abraçadeira de 31.8mm, top-swing, dual-pull
DESVIADOR TRASEIRO
Shimano Altus, 8 velocidades
MANÍPULOS MUDANÇAS
Shimano SL-M310, 8 velocidades, Rapidfire
CASSETE
Shimano 8 velocidades, 11-32d
CORRENTE
KMC X-8, 8 velocidades, elo Missing Link reutilizável
PEDALEIRA
SR Suntour, 8 velocidades, eixo de interface quadrado, cremalheira exterior substituível, com guarda-corrente
CREMALHEIRA
48/38/28, com guarda-corrente
EIXO PEDALEIRO
Interface quadrado, rolamentos de caixa
PEDAIS
Corpo de plástico compósito, rolamentos de esferas soltas, com reflectores
AROS
Alex 700c em alumínio, parede dupla com flancos maquinados, união reforçada, 32f
CUBO DIANTEIRO
Aperto rápido de 5mm, eixo de aço, rolamentos de esferas soltas vedados, porcas de aperto duplas
CUBO TRASEIRO
Vedação dupla, porcas de aperto duplas,aperto rápido de 5mm
RAIOS
Inox, 2.0mm (14g)
PNEU DIANTEIRO
Specialized Borough XC Sport, 60 TPI, flanco de arame, 700x45c
PNEU TRASEIRO
CÂMARAS DE AR
Válvula Schrader
SELIM
Specialized Body Geometry Hardrock, carris de aço, protectores à frente e atrás, 143mm de largura
APERTO ESPIGÃO
Alumínio, cabeça de 2 parafusos, 12.5mm de recuo, 27.2mm
ABRAÇADEIRA ESPIGÃO SELIM
31.8mm, alumínio extrudido e maquinado
NOTAS
Protector de escora, suporte de desviador, manual do utilizador
Agradeço comentários.
Chain: KMC Z-7
GT Transeo 4.0
Type of Frame
Fork
Crank
Bottom Bracket
Shifters
Cog Set
Chain
KMX HG-40, 8-speed
Front Derailleur
Shimano FD-M191
Rear Derailleur
Rims
Front Hub
Rear Hub
Spokes
Tires
Pedals
GT Nylon trekking
Front Brake
Rear Brake
Brake Levers
Handlebar
Stem
GT Alloy Ahead type
Headset
Saddle
Seat Post
QUADRO
FORQUETA
CAIXA DIRECÇÃO
AVANÇO
GUIADOR
PUNHOS
TRAVÃO DIANTEIRO
TRAVÃO TRASEIRO
MANETES TRAVÃO
DESVIADOR DIANTEIRO
DESVIADOR TRASEIRO
MANÍPULOS MUDANÇAS
CASSETE
CORRENTE
PEDALEIRA
CREMALHEIRA
EIXO PEDALEIRO
PEDAIS
AROS
CUBO DIANTEIRO
CUBO TRASEIRO
RAIOS
Inox, 2.0mm (14g)
PNEU DIANTEIRO
PNEU TRASEIRO
CÂMARAS DE AR
Válvula Schrader
SELIM
APERTO ESPIGÃO
NOTAS
