Bom dia amigos do pedal,
Vou me lançar na roda 29, estou indeciso entre estas 2:
SCOTT SPARK 29 COMP http://www.scott-sports.com/global/pt/products/221702007/bike-spark-29-comp-m/
SPECIALIZED CAMBER 29 http://www.specialized.com/pt/en/bc/SBCProduct.jsp?spid=61510&scid=1100&scname=Mountain
O que sugerem? Já tiveram experiência com roda 29?
Obrigado amigos, e boas pedaladas!!!
[h=1]Spark 29 Comp[/h]
http://dfp2hfrf3mn0u.cloudfront.net/221/221702_14673_png_zoom_1.jpg
Bike Spark 29 Comp
Loading zoom
Click on image to zoom in
http://www.forumbtt.net/global/pt/p.../;jsessionid=B0FC538C4394404D0B3D77F60B65FC9Ehttp://www.forumbtt.net/global/pt/p.../;jsessionid=B0FC538C4394404D0B3D77F60B65FC9ESpark 29 Comp
The Spark 29 Comp is a full suspension aluminum 29er with Shimano drivetrain and brakes which is lightweight, durable, affordable and retains all the great geometry and ride of its carbon cousins.
Frame: Spark 29 alloy 6061
Fork: Rock Shox XC 32 29 TK, lockout, 100mm
Shock: X-Fusion E1 RL, Lockout, 100mm
Group set: Shimano SLX / Alivio
Brakes: Shimano BR-M446 disc brakes
Find a dealer
[h=3]Spark 29 Comp[/h]
Model221702
Sizes
We’ve saved even more weight by eliminating bulky brake hardware for mounting the rear caliper and i.....
Read more ...
Product nameBike Spark 29 CompSizesS, M, L, XL FrameSpark Alloy 6061 custom butted, hydroformed tubes, tapered Headtube, replaceable derailleur hanger, 135mm, U-Mono Link, rear PM 160, 100mm rear travelForkRock Shox XC 32 TK 29, Coil spring, Alloy Steerer, Lockout, rebound adjustable, 100mm travelHeadsetRitchey OE 1 1/8“, semi integrated 44/50mmRear DerailleurShimano SLX, RD-M662 SGS, Shadow Type, 27 SpeedFront DerailleurShimano SLX, FD-M660-E, DMShiftersShimano Alivio, SL-M430, Rapidfire plus, w/gear indicatorBrake LeversShimano BL-M445 DiscBrakesShimano BR-M446 Disc, 180/F and 160/R mm RotorCranksetShimano FC-M430-8 Octalink, 44x32x22 TBB-SetShimano ES25 Octalink, 73-118mmHandlebarScott Pilot T OS 31.8mm, T shape Flat, 680 mm, 9° bendStemScott Comp, Oversize 31.8mm, 1 1/8“, -6° anglePedalsWellgo C-128SeatpostScott Comp zero offset, 31.6mmSeatScott RacingFront HubScott Team Disc CLRear HubShimano FH-RM66 Disc CLChainShimano CN-HG53CassetteShimano CS HG-50 -9, 11-34 TSpokesDT Swiss Champion Black 1.8mmRimsAlex XC-49 Disc, 32H, EyeletsTiresSchwalbe Rocket Ron, 29 x 2.25, 50EPI, Active LineRear ShockX-Fusion E1 RL, 165 x 38mm, rebound adjustable, LockoutRemote SystemNil
FIND DEALER
SHARE
PRINT
COMPARE
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[/TD]
[/TR]
Bike Spark 29 Comp
Loading zoom
Find a dealer
Model221702
Sizes
- S
- M
- L
- XL
- Technology
- Specs
- Geometry
- Size chart
Read more ...
FIND DEALER
SHARE
COMPARE
REAR SHOCK | RockShox Ario RL, air spring, rebound adj. and LO, 200x47mm | |
FORK | RockShox Recon Gold TK 29, TurnKey damper, Solo Air, alloy steerer, LO and reb adj., disc only, 110mm travel | |
HEADSET | 1-1/8" upper and lower, Campy-style cartridge bearings for integrated alloy HT | |
STEM | Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable rise, S: 60mm, M: 75, L:90, XL/XXL:105mm | |
HANDLEBARS | Specialized All-Mountain low-rise, 6061 butted alloy, 720mm wide, 8º backsweep, 6º upsweep, 31.8mm | |
GRIPS | Specialized lock-on, S/M: Grappler, Others: Grappler XL | |
FRONT BRAKE | Custom Avid Elixir 3 R SL, tool-less reach adj., alloy backed organic pad, HS-1 rotor S/M:180mm, Others: 200mm | |
REAR BRAKE | Custom Avid Elixir 3 R SL, tool-less reach adj., alloy backed organic pad, HS-1 rotor S/M:160mm, Others: 180mm | |
BRAKE LEVERS | Custom Avid Elixir 3 R SL hydraulic, tool-less reach adj. | |
FRONT DERAILLEUR | Shimano SLX M660E, E-type for DMD, top-swing, bottom-pull, | |
REAR DERAILLEUR | Shimano Deore XT Shadow M772, 9-speed, SGS long cage | |
SHIFT LEVERS | Shimano Alivio, 9-speed, trigger, M430 | |
CASSETTE | Shimano 9-speed HG20, 11-34t, | |
CHAIN | KMC X-9, 9-speed, reusable Missing Link | |
CRANKSET | Shimano Hollowtech, Octalink spline, replaceable rings, S: 170mm, Others: 175mm | |
BOTTOM BRACKET | Shimano, Octalink spline, cartridge bearing, 73mm | |
PEDALS | Resin Test Ride Pedals with toe clips, CEN std. | |
RIMS | Custom Alex, disc, pinned and eyeleted, 27mm, 32h | |
FRONT HUB | Specialized Hi Lo disc, OS 28 end caps, sealed cartridge bearing, QR, 32h | |
REAR HUB | Specialized Hi Lo disc, double-sealed cartridge bearing, QR, 32h | |
SPOKES | Stainless, 2.0mm (14g) | |
FRONT TIRE | Specialized Purgatory Control, 60 TPI, 2Bliss ready, aramid bead, dual-compound, 29x2.2" | |
REAR TIRE | Specialized The Captain Sport, 60 TPI, wire bead, 29x2.0" | |
SADDLE | Specialized Body Geometry Riva, 143mm width | |
SEATPOST | 6061 alloy, 2-bolt micro adjust, setback head, 30.9mm, S/M:350mm, others:400mm | |
SEAT BINDER | 34.9mm clamp ID, 7050 hard anodized alloy collar w/ QR, black | |
NOTES | Protective clear coat, derailleur hanger, reflectors, owners manual |
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[/TD]
[/TR]
