Podem tirar qualquer dúdida....
Travel 80/100/130mm, 80/100mm, 85-130mm
Travel Adjust All-Travel, All-Travel, U-Turn
Weight* 2071g (4.5 lbs), 2263g (4.99 lbs), 2400g (5.3 lbs)
Spring Solo Air, Solo Air, Coil
Spring Adjust Air pressure via a single Schrader Valve, Air pressure via a single Schrader Valve, Change Spring
Damping Motion Control
Damping Adjust External rebound, low speed compression to 'Lock', fixed Floodgate, External rebound and TurnKey lockout
Lowers Magnesium, IS disc mount
Crown Forged, 6061 T-6 hollow aluminum
Steerer Tube 4130 steel 1 1/8"
Upper Tubes 32mm 4130 tapered wall steel, chrome
Standard Colors Black, Diffusion Silver, Diffusion Black (AM), White (AM)
Options Remote, Boss or disc specific lowers, 29er
Suggested Rear Shox Ario, Bar
Upgrade Over 302: Motion Control damping, Solo Air spring, tapered wall 4130 steel upper tubes
Max. Recommended Rotor Size 210mm
Notes *Weight based on full length standard steerer
