Alem da FS que o Nuno Nogueira que chegou abaixo dos 8Kg uma das mais leve que vi até agora é uma MSC Koncept Carbon a pesar 6965gr -
Link e penso que ainda podia ficar mais leve. Isto, para mim, é que é uma FS Super WW.
A lista do material:
Brake: (Front) – Formula R1 (black polished, carbon lever, carbon clamp) - 160.4g
Brake: (Rear) – Formula R1 (black polished, carbon lever, carbon clamp) – 167.8g
-Rotor: (Front) - Kettle Cycles 160mm – 54.8g
-Rotor: (Rear) - Kettle Cycles 140mm - 43.0g
-Rotor bolts - 10xTi + 2xalu – 11.6g
-Rear Adapter: (KCNC 140mm) + 2xalu m6x14 – 12.9g
Caliper bolts - 2xTi + 2xalu m6x16 – 10.3g
Cables - Shimano Di2 tuned(modified internal battery) - 82.8g
Cassette - 11-28 Shimano Dura Ace(Nino Ti tuned) - 163g
Chain - KMC X10 SL Gold (105 links) – 235.4g
Crankset - THM Clavicula MTB 2x10 (FRM Pro 40t, R2-bike 26t – 521.4g
Derlr. (Front) - Shimano Di2(alu. bolts; Smud clamp) - 123.8g
Derlr. (Rear) - Shimano Di2(alu. pivot bolt) - 213.9g
Fork - DT Swiss XRC 100 TwinShot(carbon cap) - 1146.6g
Frame– MSC Koncept Carbon M (DT Swiss XR damper, KCNC Radiant R1 headset bearings*, Ti/Alu. bolts, derr. Hanger, bikeshield protective foil) – 1567.9g
Grips – Extralite Ultragrips (Cut) – 13.2g
Handlebar - AX-Lightness Poseidon UD 25.4x580mm (Bar-end use) – 81.9g
Pedals - Crank Brothers Egg Beaters 4Ti (Ti springs, alu. nuts, plastic sleeves) – 146.9g
Seat - 0g
Seatpost - Berk Seat/Seatpost combo(31.6x350mm) - 137.8g
Seatpost Clamp - Smud Carbon SL – 4.8g
Shifters - Shimano/Cateye tuned - 19.8g
Skewers - Tune DC 16/17 – 35.4g
Stem - Syntace F99 75mm (Ti bolts) – 83.7g
Headset – KCNC Radiant R1 (Tune BuBu Cap) – 8.2g*
Top-cap - Soul Kozak Light-bike edition (Cut,hollow) – 3.7g
Expander – Extralite Ultrastar (polished) – 8.7g
Tire (Front) - Tufo XC2 Plus - 462.6g
Tire (Rear) - Tufo XC2 Plus - 468.4g
Tubes: Glue - 30g
Wheel Front:
-Hub - Extralite HyperFront 28h 9mm - 79.4g
-Rim - Ax Lightness SRT CC 28h – 229.2g
-Spokes - Sapim Superspoke - 103.2g
-Nipples – Sapim alu. – 9.8g
-Rim Tape - 0g
Wheel Rear:
-Hub - Extralite HyperRear 28h - 167.7g
-Rim - Ax Lightness SRT CC 28g - 229.4g
-Spokes - Sapim Superspoke - 106.8g
-Nipples - Dt - 9.8g
-Rim Tape - 0g
-(Misc.) – Bar plugs, zip-ties, spacer, carbon paste – 10g
Total: 6965.3g or 15.36lb
X.
