Andre.Pepe
O que acham da Scott Genius 940? É alguma coisa de jeito? Acham que vale a pena?
Ficam as specs:
Frame: Genius 29 Alloy 6061 custom butted hydroformed tubes / tapered Headtube IDS SL dropout for 135 x 5mm U-Mono Link / rear 180PM BB height adj. / 130mm rear travel.
Rear Shock: Scott DT M3 / 3 modes Lockout-PL-AT,Ball joints / 190 x 50mm / reb. Adj.
Fork: Fox 32 Float Evolution CTD Air,CTD remote damper with 3 modes,15mm QR axle / tapered steerer,reb. Adj. / 130 mm travel
Headset: Ritchey Comp Plus Tapered 1.5 inch - 1 1/8 inch,semi integr. OD 50/61mm / ID 44/55mm
Stem: Syncros Pilot TR1.5,2014 / 4D forged / oversize 31.8mm,1-1/8 inch / 6 degree angle
Speed: 30
Front Mech: Shimano SLX FD-M670-E / DM
Rear Mech: Shimano SLX RD-M670 SGS,Shadow Type / 30 Speed
Chainset: Shimano FC-M552,2-piece Design,42Ax32Ax24T
Bottom Bracket: Shimano SM-BB71-41A / shell 41x92mm
Cassette: Shimano SLX CS-HG62-10,11-36 T
Chain: KMC X10
Front Brake: Shimano BR-M596 Disc,180 mm SM-RT64 CL Rotor
Rear Brake: Shimano BR-M596 Disc,180 mm SM-RT64 CL Rotor
Rims: Syncros XC-49 Disc,32H / Eyelets,
Front Hub: Formula CL81 / seal bearing type
Rear Hub: Shimano FH-M595 Disc CL
Tyres: Schwalbe Nobby Nic Performance,29 x 2.25 / 67 EPI Kevlar Bead,Dual compound Front Schwalbe Nobby Nic Performance,29 x 2.25 / 67 EPI Kevlar Bead,Dual compound Rear
Seatpost: Syncros FL2.5 / 31.6mm
Aceitam-se opiniões
Ficam as specs:
Speed: 30
Chain: KMC X10
Aceitam-se opiniões
