Rodas Mavic 29" - FINALMENTE
SURFAS
É mesmo finalmente!! Uso Mavic Crossmax desde 2002 e à 2 anos testei a Tallboy com as C29Max que se equipavam às Crossmax ST, mas a nível de rigidez nada parecido, era apenas uma "modificação" da ST com um aro de 29"!! Estas foram feitas de raiz para 29"
Podem ler aqui a pesquisa feita pela Mavic afim de proceder a umas rodas 29" afim do nome Crossmax.
" Mavic had planned a Crossmax SLR 29 last summer as a 2012 product, but development took longer than they thought so the launch was delayed until now. Initial prototypes simply made a 29er version of the Crossmax, but it was flexy and weak.
Mavic’s engineers said there’s a cubic decrease in stiffness as diameter grows. So, a 29er wheel would be about 39% less stiff than a similarly built 26″ wheel. A 29er wheel also has 40% more inertia, and spokes have a lower frequency but higher intensity stress, which can affect reliability. These are the challenges, skip through to see how they overcame them and more…
They tested more spokes (24 rather than 20), which fixed stiffness but added weight. They also tried stronger spokes and keeping it at 20 spokes, and that gave them the strength they wanted with minimal weight increase. But, in both cases, they noticed cracks appearing in the rim.
Interestingly, Cannondale test riders were saying that with 24 spokes, the wheel was more comfortable because spoke tension could be lower. With 20 spokes it was harder, stiffer and faster. That translates to racier, and that’s what they preferred.
The solution was to increase the thickness of the rim’s sidewall extrusion by 0.6mm. It’s a surprisingly small amount of extra material, but it solved the cracking problem. They also adjusted their ISM 3D milling from what’s done on the 26″ rim to balance strength with weight savings. Great, right? Not yet, this led to driveside radial lacing spokes breaking. They fixed this by giving only those spokes a special bead blasting treatment that increased strength without adding weight. After all this, the wheels held up in their field and lab tests.
Claimed weight for the new Crossmax SLR 29 is 1620g (755g front / 865g rear). Hubs work with all standards – Front 9/15 and rear 9/12 x 135/142 and they’ll come with all axle adapters in the box. And, as spied earlier, there’s a Lefty version, too! Spokes are their Zicral bladed spokes. Should be available in early June. $999.90 msrp.
While the SLR presented the most technical challenges because it had to be super lightweight to live up to expectations, the ST needed to be strong since it’s aimed at the All Mountain category. Surprisingly, Mavic says very little special features were needed to grow the wheel from their 26″ version and it still exceeds all of their test standards. It uses the same hubs as the SLR, the differences are that the rims don’t get the ISM 3D treatment, just basic ISM, and their round Zicral spokes with 24 front and 20 rear. So, while the weight difference between the two sets isn’t massive, but it’s rotational weight so the difference in feel should be more dramatic than the numbers may imply.
Claimed weight is 1710g (825 front / 885 rear) and it works with all axle standards, including Lefty and a 20mm front thru axle…something the SLR doesn’t have, but they come set up for 15mm thru axle front and other front axle adapters are available aftermarket. This and the Crossride 29 should be available in the fall around Eurobike time (late August/early September). $824.90 msrp.
The Crossride brings Mavic’s wheels to the masses. Claimed weight is 2020g thanks to reinforced rims for the larger wheel size. It uses standard spokes and nipples and downgrades to their TS-2 two-pawl engagement system. But it’s only $299.90 MSRP. It comes with 15mm front axle and 10mm QR. Other axle adapters are available separately.
Rim width is 19mm inside on all three. The SLR and SL are available in either 6-bolt or Centerlock disc brake hubs. The Crossride is only available in 6-bolt.
COMPARISONS & ACTUAL WEIGHTS
2013 Mavic Crossmax SLR actual weights: 755g front, 882g rear (with quick release axle endcaps).
2013 Mavic Crossmax ST actual weights: 831g front, 893g rear (with 15mm thru front, quick release rear axle endcaps).
2013 Mavic Crossride Disc 29er actual weights: 831g front, 893g rear (with 15mm thru front, quick release rear axle endcaps).
FiCaçador
Elos Rápidos
Acho que mesmo quem prefere as rodas da Mavic tinha expectativas de as SLR serem mais leves, agora "super lightweight" é que estas SLR não são, nem estão lá muito perto sequer.
TheShadow
Acho preferível serem mais pesadas e serem duradouras do que tirar peso e andar sempre com elas empenadas ou com raios partidos.
Uso crossmax ST (cuco preto) que comprei em 2ª mão.
Já levaram porrada de todas as maneiras e até agora 0 problemas.
SURFAS
O conceito de supe light da Mavic é diferente de outras marcas. Leveza sim, mas que daqui a 5 anos as mesmas Mavic tenham muitos kms e muitas porradas para contar e sem muitos problemas.
Mas se queres mesmo superlight vê estas EASTON EC90 Carbon 29er com um peso espectacular de 1440g.
Picão
Pois... cerca de 100 gramitas mais pesadas que as 26... e o preço ''upa upa'' cerca de $999!!!
Sou fã das mavic em 26 tive SL e SLR mas acho que com a 29er vou passar ao lado...:(
Tribas
Boas , tenho de meter uma rodas novas na minha santinha, tenho uns cubos Hope desde 2003 e já estão a entregar a vida ao criador... , e essas Slr são realmente muito bonitas e dizem que estão melhores que as SLR 26..... ando a ver umas custom numa loja alemã...... cubos DT suiss 240 S com aros ZTR crest.. ando indeciso pois as SLR sao muito bonitas realmente.... .. mas as DT suiss ficam 1/3 mais baratas que as Slr e dizem que são melhores..... concordam???
pmgf
Melhores não sei se serão. Os cubos DT SWiss são bons, ficas muito bem servido com essa montagem. Penso que o preço dessas rodas está muito abusado para o peso que têm. São rodas de combate, mas mesmo assim... Também ha outras opções. Tenho umas AC de 1600gr e estou muito contente com as rodas.
Boas, a minha 29er tem apenas 2 semanas mas o que posso dizer é que com as Mavic C29SSMAX já fiz um "Q.P.M."de 60km e 1900msa aqui no meu quintal (Sicó) e elas são muito confortantes e ao mesmo tempo têm uma super rigidez lateral que será difícil de ser igualada por outras desta mesma medida.
SURFAS
Desculpa discordar, achei-as pouco rígidas mas comparando com as minhas ST de roda 26". Aliás quando andei com a Tallboy foi dos pontos negativos que mais me marcou.
Já agora, uma foto do facebook, as SLR...
Pernalonga
Em termos de qualidade são sem duvida garantidas.
Com o novo cepo de embraiagem FTS-4 ficam muito mais fiaveis, em termos de rigidez nada a apontar.
O peso não é tudo existem outras variaveis que tambem são importantes para classificarmos umas rodas, depende do ponto de vista e das realidades de cada ciclista.
Mas que são umas rodas ao mais alto nivel isso è inquestionavel.
Já estão disponiveis.
