Tahoe PRO MSRP:$ 1,449
Tahoe PRO
* Specs & Geometry
* Technology
* Reviews
Print Specifications & Geometry
Specification
Sizes XS, S, M, L, XL
Color(s) Gloss Black
Main frame NEW Fuji Altair 2 custom butted aluminum with PoweCurve down tube, Tri shaped top tube, Oversized seat tube and Integrated head tube, double water bottle mounts
Rear triangle Fuji Altair 2 custom butted aluminum with Edge S-bend MonoStay, Cold forged dropout with CNC'D disc mount and replaceable hanger
Fork Rock Shox Recon SL Air w/PopLoc Remote LO & 100mm Travel
Crankset NEW Shimano Deore, 22/32/44T Alloy outer ring
Bottom bracket Shimano ES-25 Octalink Cartidge Sealed Bearing
Pedals Wellgo ATB w/steel cage, toe clips and straps
Front derailleur NEW Shimano Deore, 34.9mm
Rear derailleur Shimano Deore XT Shadow
Shifters NEW Shimano Deore Rapid Fire, 27-speed
Cassette Shimano HG-50, 11-34T 9-speed
Chain KMC HG-73
Front hub NEW Shimano Deore Sealed Bearing Disc, CL 32H
Rear hub NEW Shimano Deore Sealed Bearing Disc, CL 32H
Spokes 14G Stainless Steel
Rims Alex DP-17 Disc Double Wall w/ Single Eyelet 32H
Tires Continental Race King 26 X 2.2"
Tubes CST Lite presta
Brake set NEW Shimano Deore Hydraulic Disc, 160mm Rotor
Brake levers NEW Shimano Deore Hydraulic Forged Alloy
Headset V.P. A-42E 1 1/8" Press Fit Integrated, 30mm spacers
Handlebar Fuji CGC Riser 15mm double butted aluminum 31.8mm
Stem Fuji CGC Ultalite Forged Alloy +/- 7 degree
Tape/grip Fuji Dual Density Kraton rubber
Saddle WTB Rocket V Comp custom
Seat post Fuji CGC Forged Al micro adjust, 350mm
Seat clamp Fuji Superlite Alloy QR, 34.9mm Laser Etched
Weight- lb./kg. 13.05kg / 28.77lbs
espero ter ajudado
boas pedaladas
