Depois de uma sessão fotográfica digna, cá está a minha princesa...
QUADRO: Scott Genius alum. 6061 Custom Butted hidroformado monocoque,rolamentos aeronáuticos selados/ 150mm curso
SUSPENSÃO DIANTEIRA: Fox 32 Talas RL / Air spring lockout & reb. A. / 3 Travel position 100-125-150mm travel
SUSPENSÃO TRASEIRA: Scott Equalizer 2 / 3 Modos Lockout-Traction-Full travel /apoios c/ rolamentos/ duplo rebound / controlo rem. trac loc 2
HEADSET: FSA Nr.9 / 1 1/8" / alloy cups semi integrated 44/50mm
DESVIADOR TRASEIRO: SRAM X-9 medium cage 27 Speed
DESVIADOR DIANTEIRO:Shimano SLX FD-M660E-Type direct mount
MANIPULOS: SRAM X-9 Trigger adjustable clamp with matchmaker clamp
MANETES DE TRAVÃO: Avid Juicy 5
TRAVÃO: Avid Juicy 5 185/F and 185/R mm Rotor
CRANKSET: Truvativ Firex 3.3 Giga X Pipe 44Ax32Ax22A T
EIXO PEDALEIRO: Truvativ GXP / shell 73mm&E DM
GUIADOR: Scott Pilot 22 Pro / 2014 Alloy 22mm rise / OS / 660mm Scott lockon grips
AVANÇO: Scott MC pro 4 bolt Clamp / OS 1-1/8" / 6° angle
PEDAIS: Shimano PD-M520 Clipless pedal
ESPIGÃO: Scott RC 03-60 / 34.9mm
SELIM: Scott Genius / CRMO rails
CORRENTE: SRAM PC 951
CASSETE: SRAM PG 980 11-32 T / alloy spider
PNEUS:Schwalbe Nobby Nic 26 x 2.25 / 67 EPI Kevlar Bead Evolution / triple compound
Rodas: Mavic Cross Ride Disc
Peso: 13,200kg
