:arrow: link
Cyclaire pumps are compact in size, massive in capability and quicker and easier to use than most conventional pumps. Ideally suited to bike tyres, the Cyclaire Pump will work well pushchair tyres, wheelchair tyres, scooter / moped tyres and similar.
Cyclaire pumps are better because of the unique pull–cord system, which enables you to get a really long stroke – as long as your arm – from a small, portable pump. This means it's almost like having a full–sized floor pump (or "track pump") in a six–inch case.
The pull-cord system is designed to make it easy to reach high pressures. Unlike some conventional pumps that require a lot of strength in the arms and shoulders to force the air into the tyre as the pressure rises, the Cyclaire mechanism takes the strain instead of you - the last 10psi is just about as easy as the first 10psi.
Two versions of the Cyclaire pump are available: The Cyclaire Rapid and The Cyclaire Plus.
Choose the Cyclaire Rapid for a tyre that needs up to 80psi pressure: Moutain bikes, Mopeds, BMX, Wheelchairs, Mobility Scooters, Pushchairs and Prams, Kids bikes, Wheelbarrows
Choose the Cyclaire Plus for tyres that need up to 120psi pressure: Road bikes, Hybrid bikes, Track bikes.
It's a Cycling Plus "Innovation Of The Year"
Easy to use, no crouching over the valve! Just stand up straight, and pull the strap to pump
