Ajudem.me neste dilema das Cubes!
hugooazevedoo
Boa noite pessoal,
CUBE ANALOG DISC 26er
http://img841.imageshack.us/img841/1427/analogdiscblack.jpg
  • Alu Lite AMF 6061 RFR-Geometry, Disc only
  • black 'n'_white
  • Rock Shox XC 28, 100mm, Poploc
  • FSA No.10 semi-integrated
  • Easton EA30 Oversized
  • Easton EA30 Lowriser Oversized
  • CUBE Performance Grip
  • Shimano SLX RD-M662 Shadow 9-speed
  • Shimano FD-M430 Top Swing 34,9mm, 9-speed
  • Shimano Acera SL-M390 Rapdifire-Plus, 9-speed
  • Shimano BR-M445 hydr. discbrake(160/160mm)
  • Shimano FC-M430 44x32x22T, 175mm, with BB-UN26
  • Alex ZX 24
  • Shimano HB-RM66 Disc
  • Shimano FH-RM66 Disc
  • DT Industry
  • Schwalbe Smart Sam 2.25
  • Impac AV14
  • Fasten Alu
  • Scape Active 8
  • Easton EA30 31,6mm
  • Scape Varioclose 34.9mm
  • 13,5 kg
613,79 €
CUBE ACID 26ER
http://img135.imageshack.us/img135/3488/6a00d83451f74269e201676.jpg
  • black 'n'_white
  • Rock Shox Recon TK Air, 100mm, Poploc
  • Shimano Deore XT RD-M780 Shadow 10-speed
  • Shimano Deore FD-M590 Top Swing 34,9mm, 10-speed
  • Shimano Deore SL-M591 Rapidfire-Plus, 10-speed
  • Shimano FC-M522 42x32x24T, 175mm, with BB-ES25
  • Alex ZX 24
  • DT Industry
  • Impac AV14
  • Fasten Alu
  • Scape Active 8
  • black 'n'_white: 12,8 kg // grey 'n'_blue: 12,8 kg
    809,09€
    CUBE ANALOG DISC 29ER
    http://img835.imageshack.us/img835/8226/cube29analog.jpg
    • Alu Superlite AMF 6061 Double Butted, Agile Ride Geometry, Disc only
    • white 'n'_black
    • Suntour XCM 29 Lockout 100mm
    • Shimano Deore RD-M592 Shadow
    • Shimano SLX FD-M661 Direct Mount, 9-speed
    • Shimano FC-M430 44x32x22T, 175mm, 3x9 speed
    • RFR ZX24 29
    • Alex ZX 24 29
    • DT Swiss Industry 2.0
    • Schwalbe Rapid Rob Performance 29x2.25
    • Schwalbe MTB AV19 29
    • Fasten Alu
    • Scape Active 8
    • Easton EA30 30,9mm
    • 13,9 kg
    613,79 €
    CUBE ACID 299er
    http://img823.imageshack.us/img823/3337/29acidn.jpg
    • black 'n'_white
    • Rock Shox XC 32 29, 100mm, Poploc
    • Shimano SLX FD-M661-10 Direct Mount, 10-speed
    • Shimano FC-M522 42x32x24T, 175mm, with BB-ES25, 3x10 speed
    • RFR ZX24 29
    • Fasten Alu
    • Scape Active 8
    • 13,2 kg
    809,09€
    Bem tentado simplificar o máximo e que tenham toda aqui a informação. Gostaria das vossas opiniões em relação a esses modelo.
    A minha pergunta principal é: valerá os cerca de 200€ a mais pela Acid ? com a Analog ficarei mal servido? (neste momento a minha bike é uma da makro que ja acho muito boa xDDD)
    Eu estou mais inclinado para a Cube Acid 29er (depois de muito ler, e ver videos, e tentar perceber quais as diferenças entre 26/29er) e depois disso tudo (ainda sem ter experimentado) fico com o bichinho das 29er!
    ps.: a filtragem do meu gosto entre as marcas e design das bikes, vou sempre cair nas Cube
    :rolleyes:
    boas pedaladas,
    cumps!
jamb
Eu também tive esse dilema mas optei por uma Attention... é mais barata que a Acid e melhor que a Analog... só que a minha é 26", segundo sei as 29" puxam mais pelo "coração"
hugooazevedoo
por acaso também tinha visto essa Attention! e em relação ao desempenho e resistência dela? o meu interesse tmb é a durabilidade dos componentes, estando eu a fazer cerca de 120/150km semanais(sei que deve ser pouco para a bike, mas fico smp na duvida):eek:
e das 29" também ja me tinha apercebido que é preciso ter um bom motor para puxar a carroça :rolleyes:
jamb
até á data não me tem deixado mal, já a tenho á uns 3 meses e já fiz umas largas centenas de km´s, desde que a limpe e lubrifique sempre que necessário.
CUBE_LTD
Na minha opinião e como prefiro 26" escolhia a CUBE ACID 26" também porque trás uma Recon a ar que faz muita diferença para as outras a molas que são de entrada de gama.
mrespt
O quadro da analog,attention,acid tem a mesma geometria, só muda os gráficos do quadro e mudam os componentes. Claro que a acid é superior, daí o preço mais elevado.
Depende de ti e da tua carteira. Se fores a ver o material que a acid tem que a analog não tem, para a equiparares, secalhar vais gastar mais que os 200€. Compara nas lojas online. A suspensão, desviador XT, deore, suspensão...
Também estive nesse dilema e acabei por trazer a acid em 26".
BTTR
Eu ia para a Acid 26''.
É a mais leve e como parece que és "macarico" como eu, a 29'' é capaz de ser puxada demais por agora.
hugooazevedoo
pelos vistos a acid é um bom investimento, e uma escolha unânime! la maçarico sou um pouco xD nao tenho grande tecnica ainda :O
mais uma vez, obrigado pelas dicas!
cedg
29" é de facto muito complicado puxar...em estrada ou em terra mas em recta o pessoal diz maravilhas,ag quando se trata de puxar pela burra a subir...haja pulmão e perninhas. Tanto quanto sei a Analog 26 está esgotada a nivel nacional(mas pode haver algumas lojas que ainda tenham em stock), lá terás de ir para a opiniao do pessoal. ;)
gfilipe
http://img841.imageshack.us/img841/1...gdiscblack.jpg
Optaria por esta!Para dar a minha opiniao, e tendo em conta o que vais fazer com bike descartei logo as 29er,
a minha escolha pela ANALOG disc é apenas por poupares 200euros, e ficas com uma bike fiavel na mesma, e mais tarde os 200euros dao para veres o que achas que necessita de upgrade no uso que das.
por exemplo, podes trocar rodas completas ou a suspencao por melhor pela diferenca dos 200euros, dando o teu material a troca ou nao.
È a minha opiniao atençao, se nao te importares a cabeca de dares mais dinheiro opta pela ACID que ja tem uma recon, mas acho que se fosse eu nao o faria.
abraço.
lucelima
Penso que a Acid vale os € a mais. Na meu caso ia para a 26", mas é um gosto pessoal e de momento não me vejo a ir para 29". Mas se tens dúvida entre qual roda escolher era bom que experimentasses uma 29". Quanto a pernas tanto são necessárias para 29" ou 26" e as desvantagens das 29" são no peso e nos arranques mas depois é velas a rolar bastante rápido.
ruiki
Tenho uma Cube LTD SL 29er. confirmo que, com a mesma relação de transmissão, a pedalada a subir fica mais pesada, o que é natural. Convém, pois, estar em forma para puxar o animal. Mas a verdade é que, em termos de tracção, subo coisas que antes não subia.
Melhor do que ouvir palpites para decidir, é mesmo experimentar as diferenças. eu sou de coimbra. se pretenderes experimentar a minha 29er, apita.
hugooazevedoo
boaa tarde,
mais uma vez agradeço toda as opinioes!
cada vez mais fico virado para as 29er, so vejo vantagens nas 29er a unica desvantagem que tenho visto assim significativa.. sao as pernas que iram sofrer mais um pouco :O mas e daí? o aproveitamento e divertimento é muito superior ao ponto de esquecer essas "pequenas" dificuldades na pedalada ! :eek: e smpre dá para experimentar algo novo :D
ps: um obrigado por serem smp tao prestaveis a todos os niveis aqui no forum! pena ser da margem sul ruiki :(
Jaires
Ahh grande Hugo!
Eu se tivesse no teu lugar punha de parte as 29"
Quanto às outras duas de 26" escolheria a acid. Já vi que gostas do design das cube, mas e que me dizes aqui desta http://www.canyon.com/_pt/mountainbikes/bike.html?b=2539, mais um esforço e já trazes uma bike bem melhor equipada, e para mim com um quadro também muito bonito. Esta talvez seria a minha aposta ;)
