Scott Spark 29 Elite VS Specialized Epic Comp 29
Estando eu à procura de uma nova montada, as 29er de suspensão total têm-me atraído particularmente
Dentro dos valores que estou a ponderar despender encontrei 2 opções interessantes
FRAME Spark Alloy 6061 custom butted, hydroformed tubes, tapered Headtube, replaceable derailleur hanger, 135mm, U-Mono Link, rear PM 160, BB height adjustable, 100mm rear travel
FORK Rock Shox Reba 29 RL Air, Motion Control Lockout, tapered steerer, Rebound adjustable, 100mm travel
SHOCK (REAR) DT Swiss M210, Air, ABS Spring, 165 x 38mm, Rebound adjustable, Lockout
DERAILLEUR (REAR) Shimano XT, RD-M780 SGS, Shadow Type, 30 Speed
DERAILLEUR (FRONT) Shimano SLX, FD-M660-10E, DM
SHIFTERS Shimano SLX SL-M660-10, Rapidfire Plus, 2 way release, w/gear indicator
BRAKES Avid Elixir 5S, 180/F and 160/R mm HS1 Rotor
CRANKSET Shimano XT, FC-M780, Hollowtech 2, 42Ax32Ax24A T
HANDLEBAR Scott Hot Rod Tbar OS 31.8mm, T shape Flat, 680mm, 9° bend
H'STEM Scott Comp, Oversize 31.8mm, 1 1/8“, -6° angle
PEDALS Shimano PD-M505, Clipless pedal
SEATPOST Scott Comp zero offset, 31.6mm
SEAT Scott Racing
HUB (FRONT) Scott Comp Disc IT
HUB (REAR) Shimano FH-M529 Disc IT
CHAIN Shimano CN-HG54
CASSETTE Shimano CS-HG62-10, 11-36 T
SPOKES DT Swiss Champion Black 1.8mm
RIMS Alex XC-49 Disc, 32H, Eyelets
TIRES Schwalbe Rocket Ron, 29 x 2.25, 67EPI Kevlar Bead, Performance Serie
OU
Specialized Epic Comp29
QUADRO Alumínio M5, geometria 29", 100mm de curso
AMORTECEDOR TRASEIRO Mini-Brain remoto Fox/Specialized com nova afinação para 2012, válvula de inércia com ajuste Brain Fade, 187x47mm, tubo de comprimento 29er
FORQUETA RockShox Reba RL 29, coluna de dir. cónica em alumínio, ajuste de rebound e bloqueio, dropouts standards, 100mm de curso
CAIXA DIRECÇÃO Rolamentos de caixa de 1-1/8" superior estilo Campagnolo e 1.5" inferior, sem rosca
AVANÇO Specialized XC, alumínio forjado em 3D, 4 parafusos, aperto de 31.8mm, inclinação ajustável, S: 75mm, M: 90mm, L: 105mm, XL: 105mm
GUIADOR Specialized XC recto, alumínio 2014 de espessura variável, 680mm de largura, 8° de recuo, 31.8mm
TRAVÕES Avid Elixir 7 SL exclusivo, disco hidráulico, calços semi-metálicos com base de alumínio, rotor HS-1 de 160mm
DESVIADOR DIANTEIRO SRAMX7,10 velocidades, montagem directa S3 para DMD, bottom-pull
DESVIADOR TRASEIRO SRAM X9, 10 velocidades, gaiola média
MANÍPULOS MUDANÇAS SRAM X7, 10 velocidades, de gatilho em alumínio, com abraçadeira MatchMaker
CASSETE SRAM PG-1030, 10 velocidades, 11-36d
CORRENTE KMC X-10, 10 velocidades, com elo Missing Link reutilizável, acabamento niquelado
PEDALEIRA SRAM S-1250 exclusivo, cranques em alumínio 7050, 10 velocidades duplas para XC Trail, eixo GXP, S: 170mm, outros: 175mm
Que vos parece?
Essencialmente faço maratonas...
Abraço e boas pedaladas
tinric
Ok... para equilibrar.... a epic é provavelmente a melhor bicicleta do mundo :)
Mas acho que tem pouca comparação senão vejamos (mas sou suspeito pois tenho uma Spec e adoro)
Mudanças na spec SRAM (melhor)
Amortecedor (fox com brain) sem comparação
Rodas , aros roval...
acho que de resto o pessoal olha e vê uma scott ou uma spec e diz que gosta mais de uma ou de outra...
tens que ver o que gostas mais mas também meter aí um bocadinho de razão
espero ter ajudado a confundir
#9
Mais um voto para a Epic, ou não tivesse eu uma :D.
Tal como diz o tinric, desviadores SRAM=fiabilidade e precisão, e o brain é mesmo muito, muito bom. Os travões também são ligeiramente melhores.
Não sendo eu um expert em metais, julgo que o material do quadro da Spec (alu M5) talvez seja superior ao da Scott (alu 6061).
Conconcordo com o amigo tinric. Não é por nada mas..... não há no mundo sistema de amortecimento como o nosso da spec...... Só não concorda quem nunca experimentou (venha quem vier)!! :D
1 abraço, cumpts BTTistas ;)
#11
Eu faço das palavras do Tinric as minhas palavras, não tirando mérito á Scott mas a Epic sempre será uma das melhores FS do mundo ou talvez a melhor, apesar da Cannondale ter a Scalpel que ainda dá que pensar a muita gente...ainda hoje tive com uma nas mãos...
Voltando ao que interessa, Epic sem duvida.
#13
Boas amigo,
Com que então à procura de uma nova montada...
Eu dessas duas escolhia a Scalpel 3 :) :) e até digo mais, com o conforto acrescido por ser 29er ia para uma HT e nesse caso a Flash Carbon 3 29er!...
No entanto a escolha é tua!
Abraço e boas pedaladas...
HR
#14
Também concordo plenamente com o HR.............isto é se a escolha pode recair em outras marcas e modelos além destes 2........então...Scalpel roda 26 da cannondale,...............mas se é para ir para 29, então Flash............porque a LEFTY não é provavelmente a melhor suspensão do Mundo, a Lefty é LEFTY e o resto são suspensões mais ou menos intelegentes!
#16
Mais um da opinião do HR, em primeiro Cannondale Flash carbon 29er, e se for mesmo preciso um sofá com rodas, então Scalpel alloy 29er.
Pois, faltou-me a opção da cannondale scalpel de alumínio 29, embora esta em princípio só esta disponível a partir do segundo trimestre de 2012...
#17
Só para criar mais um bocadinho de indecisão :p:
- Specialized - Garantia do Quadro vitalicia e material 2 anos;
- Scott - Garantia cinco anos e material 2 anos;
Acho a epic muito mais bonita (gosto pessoal).
Boa sorte na decisão.
Um abraço,
João Duarte
#20
Viva,
A revista espanhola Solobici (de á dois meses), faz um teste comparativo entre a Scott Spark 26 e a Spark 29 Elite (para além das Scales 26/29)
Apontam o peso da Spark 29 Elite em 12,4 Kg sem pedais.
Cumprimentos,
Francisco
