scott scale 930 2017 vs merida big nine 3000 vs KTM myroon comp.
Boas Pessoal,
tenho estas 3 maquinas e estou indeciso em qual, o valor delas é praticamente o mesmo, ronda os 1700€.
Pela vossa experiência e conhecimento qual a vossa opinião.
Ktm - http://www.ktm-bike.pt/pt/loja/2-mo...cleta-ktm-myroon-comp-29-2018-11s-detail.html
Mérida - https://www.merida-bikes.pt/18-big-nine-3000
Scott - The SCOTT Scale 930 Series boasts a super light Carbon Fiber frame. The 930 comes fully equipped with a FOX 32 Float Performance fork with three modes, along with our RideLoc technology to allow for three travel settings to always optimize your ride, and a Sram 1×11 drivetrain. FRAME Scale 2 Carbon / IMP technology / Carbon Tapered HT / PM 160 Disc / BB92 / IDS SL 142x12mm dropouts SDS Shock Damping System FORK FOX 32 Float Performance Air Grip 3 / 3-Modes / 15x100mm QR axle / tapered steerer Lockout / Reb. Adj. / 100mm travel REMOTE SYSTEM SCOTT RideLoc Technology / below Bar Remote 3 modes / integ. Grip clamp HEADSET Syncros Pro Press Fit / Tapered 1.5″ – 1 1/8″ OD 50/61mm / ID 44/55mm REAR DERAILLEUR Sram GX1 / 11 Speed SHIFTERS Sram GX1 Trigger BRAKES Shimano M506 Disc 180/F and 160/R mm SM-RT54 CL Rotor CRANKSET Sram Custom GX1 GXP PF 700 Series: 32T / 900 Series: 30T BB-SET Sram GXP PF integrated / shell 41×89.5mm HANDLEBAR Syncros FL1.5 T-Bar / Alloy 7050 D.B. T shape Flat / 9Á / 720mm Syncros Pro lock-on grips H’STEM Syncros FL2.0 / 6061 Alloy 6Á / integrated Top Cup / 31.8mm / 1 1/8″ SEATPOST Syncros FL2.0 / 10mm offset 700 Series: 31.6x400mm / 900 Series: 34.9x400mm SEAT Syncros XR2.0 / CROM rails HUB (FRONT) Syncros CL71 / 15x100mm made by Formula HUB (REAR) Syncros CL1421/ 142x12mm RWS axle / XD / made by Formula CHAIN Sram PC1110 CASSETTE Sram XG1150 / 10-42 T SPOKES DT Swiss Industry Black 1.8mm RIMS Syncros X-23 / 32H / Tubeless ready
Aguardo as vossa opiniões.
Mr.sa
Honestamente são todas muito parecidas. Se conseguisses ir aos 2000€ para uma melhoria nos componentes seria uma vantagem, porque dessas 3 parecem-me todas muito equilibradas, eu iria para a que mais gostasses.
Eu tenho uma Merida Big Nine 3000 (2018) desde Outubro. E estou bastante satisfeito com ela. A bicicleta tem um funcionamento muito eficaz, e confortável. Quer seja a subir ou a descer, muito ágil.
