Manutenção Suspensão Manitou
jmdcfigueiredo
Boas pessoal.
Alguém me pode "iluminar" sobre a manutenção de uma Manitou Skareb Super TPC 100mm!?
O meu muito obrigado desde já.
TheTraveler
Section 1: Damping Systems
Absolute and TPC Damping System Service
Disassembly Instructions for Absolute and TPC Damping
1. First the rebound knob will need to be removed. Screw the rebound all the way in (clockwise), and then remove the 2mm hex screw inside the knob by turning it counter- clockwise. Remove the knob by pulling gently away from the fork.
2. Use an 8mm hex wrench to turn the damper shaft clockwise until it can be pushed into the casting. (see Fig. 1)
3. From the left leg dropout (Left when sitting on the bike), use a 10 or 11mm wrench to remove the compression rod screw.
4. Remove crown/steer/inner leg assembly from the outer leg casting by pulling firmly on the casting. The fork uses the Semi bath Lubrication system, use caution as the oil that is in the casting will be released when the casting is removed, it is best to do this over some type of catch pan.
5. For forks with Absolute compression damping:
a. Unscrew the 2mm Allen screw that holds the adjuster knob to the assembly and remove the knob. There are two ball bearings sitting on top of springs underneath the adjuster cap. Place those aside. Using a 24mm socket unscrew the Absolute assembly from the crown. Pull the assembly out of the fork leg. Fig 2 (Note: there will be a small amount of oil that comes out of the inner leg, when the assembly is pulled from the crown)
Tive a ver o manual de manutenção da Manitou e por acaso até está muito bom.
Isto é só um exemplo do que está no manual.
Tens tudo passo a passo, medidas de ferramentas, e o que acontece a cada passo.
Algo mais tutorial que isto vai ser complicado encontrares...
TheTraveler
Tem passo a passo por escrito, fotos só tem dos passos mais importantes.
Mesmo assim vejo bastantes fotos no manual. Qual é o passo que tás com dificuldades?
jmdcfigueiredo
Em boa verdade nenhum porque ainda nem sequer tenho a suspensão mas estou a pensar comprar uma e queria ver até que ponto seria fácil mantê-la uma vez que em Portugal não há Manitou.
Porém encontrei este video na net que me parece muito bom e não deve andar muito longe disto.
Qual acham que é a esperança média de vida dos o-rings, vedantes e retentores de uma suspensão destas?
Um abraço e obrigado
P.M.
Acho que te andas a preocupar com demasiada antecedência...
Todas as suspensões precisam de manutenção, quer seja preventiva ou correctiva, e são todas muito similares... E existe muita gente em Portugal com experiência nas manitou (ainda para mais com um modelo que existiu de 2002 a 2006?).
O manual é fácil de se perceber quando se tem a suspensão à frente (lógico...).
P.M.
jmdcfigueiredo
Como dizes a suspensão já não está em produção portanto se a comprar logicamente é em segunda mão e se não encontrasse nada sobre como mantê-la ponderaria ainda mais a compra.
