Ibis Mojo HD
Discussion in 'Santa Cruz & Ibis Bicycles' started by SURFAS, 28 July 2009.
  1. SURFAS
    SURFAS New Member
    Eis a nova Ibis HD com 160mm, apesar de não ser fã da marca, pelo que tenho lido dizem ser muito boas e o quadro em carbono tem provado muito bem!!
    Tendo as mesmas linhas da irmã mais leve mas com uma geometria bastante diferente.
    Feita para levar suspensões de 160 a 180mm
    [​IMG]
    2010 Ibis Mojo “HD” Prototype Specs
    * Price and availability TBD (I hope to hop on one at Interbike)
    * 160mm of rear wheel travel.
    * DW Link Suspension
    * 26″ Wheels
    * Target weight for the frame and shock: 6.2-6.5 lbs. (we’re not there yet but are fine-tuning the layup)
    * 67 degree head angle with a 160mm fork (Brian was running a 170mm fork this weekend, you can also run a 180mm)
    * Chain stay length: 17.125″
    * Top tube lengths are the same as regular Mojos
    * 12 x 135mm RockShox Maxle rear axle
    * Post mount magnesium left dropout, carbon right dropout
    * Head Tube: Tapered steerer (1-1/8 to 1.5) or standard 1-1/8
    * Tire Clearance: Up to 2.5 (depending on knobbies)
    * Dual row angular contact bearings in the front of the lower link that have less play than standard sealed bearings. Preload adjustment is not necessary. Large 28mm x 15mm x 7mm radial bearings in the rear for stiffness and long wear.
    * The leverage ratio, like the Mojo and Mojo SL is designed for air shocks. The Mojo HD comes with a 8.5″ x 2.5″ Fox RP23. A DHX air will work on all but the small size. A coil shock is not offered because the linkage rates weren’t designed for it. We lowered the top tube to get slightly better standover than the regular mojo while having a higher BB because of the longer travel (we managed to retain the DHX air compatibility in 3 of the 4 sizes).
    * The Bottom Bracket height is 13.8″-14″ depending on tires.
    * Chain guide development is well on its way, we’ll announce compatible brands soon. The frame will not have ISCG mounts so it will not be Truvativ Hammerschmidt compatible (what are they thinking!?!?!).
    * The HD runs full cable housing. Rear brake and rear derailleur run on the down tube, with hidden swingarm housing for the rear derailleur.
    * Front derailleur (if you use one) and adjustable seatpost housing (if you use one) run along the top tube.
    Field tested, Lopes approved
    Ibis-sponsored racer Lopes spent the last week in Vars France, getting ready for and then competing in the Enduro Trophy des Nations.
    "This is an enduro style race, becoming quite popular in Europe these days, where riders compete in a number of stages over a two day period with “beaucoup” downhill," Nicol explained. "This particular event had 10 stages over two days and featured over 10,000 metres of descending. If you’re bad at math (or don’t like the metric system) that’s 32,808.4 feet of descent. Or 6.21 MILES straight down, measured vertically!
    "This race also had a bonus stage at 10 p.m. on Saturday night that didn’t count for the overall time, but the winner got an extra 500 Euros of party money," Nicol added. "Brian teamed up with WTB’s Mark Weir and Jason Moescheler to form Team USA 1. Brian notched the first win for his prototype Ibis Mojo HD on its first day of racing by winning one of the stages on Saturday, propelling the team to second overall on Saturday night."
    According to Lopes, who's no stranger to racing fast downhill and is known as one of the fittest athletes on the circuit, the Enduro race was a lot harder than he expected.
    "The toll it took on everything: wheels, tires, brakes, suspension, the body, and of course the frame were beyond what I imagined," Lopes said. "The new HD never missed a beat. For only getting the frame one week ago and with only one ride on it before packing it up for this race, it couldn’t have gone through any more of a test than the abusive one I gave it here in France.
    "It’s hard to believe that this bike isn’t much heavier than the standard Mojo, as it was eating up courses that were worthy of full-on DH rigs," the 37-year-ol California racer added. "The added travel, stiffness, clearance for larger tyres and a eight-inch rotor allowed me to take on the toughest terrain, but it’s still efficient and light enough to pedal up any hill. Another weapon is added to the ibis line up…"
  2. Kamoes
    Kamoes Active Member
    SURFAS dou-te a minha morada e podes enviar uma igual a essa para cá!
    Que estrondo de bike, mesmo linda... Essas rodas ficam aí 5*.
    HD? Alta definição? Uma bike a 1080p? Brutal!! :mrgreen: :mrgreen:
    Cumpz.
  3. SURFAS
    SURFAS New Member
    No Eurobike
    [​IMG]
  4. SURFAS
    SURFAS New Member
    Mais fotos do Interbike
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    retirado de mtbr.com
  5. SURFAS
    SURFAS New Member
  6. 100bike
    100bike New Member
    E eu que pensava que a IBIS já tinha "MORRIDO", afinal está viva e GOZA de muito BOA SAUDE ;)
  7. no180
    no180 New Member
    Uma dúvida: na foto de abertura que suspensão é aquela?? Parece-me uma rock shox sid alimentada com hormonas de crescimento!!!!!!
  8. SURFAS
    SURFAS New Member
    É uma Lyric 170mm
  9. SURFAS
    SURFAS New Member
    Ibis HD no Sea Otter
    Aqui ficam as fotos da nova HD no Sea Otter
    Já estão a ser entregues nas lojas nos USA, gostava de ver uma por cá nos trilhos
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Retitado de PinkBike.com
  10. SURFAS
    SURFAS New Member
    Mais fotos ... e pesos
    As cores serão branco e amarelo, e virá também com uma clear coat sobre o carbono e logos brancos.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    A protecção
    [​IMG]
  11. SURFAS
    SURFAS New Member
    A do Brian Lopes com Sram e jantes de carbono Edge
    [​IMG]
  12. Sir Augusto
    Sir Augusto New Member
    que espigão é aquele que ele tem montado? ks900r? ou outro?
    alguém sabe?
  13. SURFAS
    SURFAS New Member
    Isso mesmo ! :clap:
  14. SURFAS
    SURFAS New Member
    Em transparente baço
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    ATENÇÃO:
    Pelo que tenho lido, não pensem em 160mm de curso uma bicicleta de freeride, downhill ..... dizem que sobe muito bem e pedala optimamente.
  15. Sir Augusto
    Re: Ibis Mojo HD
    ainda não tinha visto esta cor!! excelente
    boa Surfas, andas sempre a surfar na net, encontras de tudo na net
  16. SURFAS
    SURFAS New Member
    Re: Ibis Mojo HD
    De tudo, do que gosto, SIM!!
    Sou fã da Santacruz à muitos anos, o meu primeiro quadro foi uma Chameleon. Mas posso afirmar que os quadros Ibis vem empatados com a Turner e o DW é tão bom ou ligeiramente melhor que o VPP (é o original) mas Santacruz é Santacruz e os quadros de carbono são MUITO MELHORES que os da Ibis!!!
  17. Sir Augusto
    Re: Ibis Mojo HD
    porquê dizes isso?factos? eu sou fã da ibis por esta ser unicamente feita em carb/magm. enquanto a santa cruz nomad carbono , penso que tem o triangulo trazeiro em aluminio... acho eu.
    mas gostos sao gostos, a minha ordem é o contrario da tua ... 1º ibis mojo hd,2ºsanta cruz nomad,, turner nao gosto muito dos quadros
    diferenças nomad vs mojo hd a nivel de peso é +/- 200gr acho eu
  18. SURFAS
    SURFAS New Member
    As Santas de carbono são todas em carbono, apenas o links de baixo e o dropout são de aluminio. As Ibis são feitas por partes, estruturalmente não são tão rigidas, dai o Lopes Link!!
    Tem os suportes dos cabos/bichas presos (por parafusos) ao quadro e não como na Santacruz, em que são uma peça só, já vi fotos de quadros estragados por ramos que agarram as bichas e arrancam os suportes e parafusos do quadro. Tal como os suportes do disco em que nesta HD são em conjunto com o suporte do eixo de magnésio e depois "colado" ao carbono, que noutras marcas, Yeti por exemplo tem dado MUITOS problemas.
    E sim as Santas de carbono são mais pesadas mas também te garanto ... duram mais!!!
    Mas digo entre a Ibis HD e a Nomad de Carbono ... se fosse para comprar uma dessas iria-me dar muito que pensar, embora sejam ligeiramente diferentes a Nomad é mais radical uma bikla para se abusar mais dela!!!!!
  19. Sir Augusto
    percebes-te mal!!.. a Ibis é mais pesada que a a Santa Cruz nomad
  20. SURFAS
    SURFAS New Member
    É ?? Pois é ... nem tinha visto isso 6.1 LBS a Nomad e 6.3 a HD.
    Da Turner não é bem gostar dos quadros, não são propriamente .... mas o DW na Turner ainda funciona melhor do que na Ibis, a geometria da Turner é melhor do que da Ibis, mas neste momento os quadros são bem mais caros e mais pesados que os da Ibis e da Santacruz.
    Gosto muito da amarela
    [​IMG]
Share This Page
