e para ja:
Specialized camber expert:
Frame:M4 hydroformed tubing, sealed cartridge bearing pivots, disc only, Command Post routing, replaceable derailleur hanger, bolt on cable guides, 120mm travelFork:Custom RockShox Reba TK, Turn Key damper, Solo Air, alloy steerer, rebound adj. w/ LO, disc only, 120mm travel Rear Shock:Custom Fox Triad II for Specialized, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal, rebound adj., 7.875x2.0"Chainset:-Chainrings:42A x 32A x 24SCassette:Shimano HG81, 10-speed, 11-36tChain Device:-Bottom Bracket:Shimano BB-ES25, Octalink spline, cartridge bearingChain:KMC X10, 10-speed, w/ reusable Missing Link, nickel platesFront Hub:Specialized Hi Lo disc, laser-etched logo, OS 28 end caps, sealed cartridge bearing, RWS, 28hRear Hub:Specialized Hi Lo disc, laser-etched logo, double sealed cartridge bearing, QR, 32hFront Derailleur:Shimano FD-M660-10E SLX, 10-speed, E-type for DMD, top swing, bottom pullRear Derailleur:Shimano RD-M772 Deore XT Shadow, 10-speed, long cageFront Brake:Custom Avid Elixir 5 SL, hydraulic disc, alloy backed organic pads, G3 Clean Sweep rotor, S/M: 185mm, L/XL: 203mmRear Brake:Custom Avid Elixir 5 SL, hydraulic disc, alloy backed organic pads, G3 Clean Sweep rotor, S/M: 160mm, L/XL: 185mmBrake Levers:Avid Elixir 5 hydraulicPedals:Resin Test Ride Pedals with toe clips, CEN std.Handlebars:Specialized XC low-rise bar, 2014 butted alloy, 680mm wide, 8 degree back sweep, 6 degree up, 31.8mmStem:Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable riseHeadset:1 1/8" upper and lower campy style cartridge bearings for integrated alloy HTGrips:Specialized lock-on, S/M: Grappler, Other: RoccaSaddle:Specialized BG Henge Comp, hollow Cr-Mo rails, 143mm widthSeatpost:6061 alloy, 2-bolt micro adjust, setback head, 30.9mm, S/M:350mm, others:400mmRims:Custom DT Swiss 445D, alloy disc, double wall, pin joint, eyelets, 24mm, 28/32hFront Tyre:S-Works "The Captain", 120 TPI, 2Bliss ready aramid bead, dual compound, 26x2.0"Rear Tyre:Specialized "The Captain" Control, 60 TPI, 2Bliss ready aramid bead, dual compound, 26x2.0"Inner Tubes:Ultralight presta valveShifters:Shimano SL-M660-10R SLX, 10-speed, trigger
Trek fuel ex6:
Frame Alpha Red Aluminum w/ABP, Full Floater, magnesium EVO Link, oversized pivot bearings, replaceable derailleur hanger, 120mm travel Front Suspension RockShox Recon Gold TK Solo Air w/air spring, rebound, TurnKey lockout, alloy steerer, 120mm travel Rear Suspension Fox Float RP-2, "trail tuned" w/ProPedal, rebound; 7.0x2.0" Wheels Wheels Shimano alloy M475 hubs; Bontrager Ranger 32-hole rims Tires Bontrager XR3, wire bead, 26x2.2" Drivetrain Shifters Shimano M590, 9 speed Front Derailleur Shimano Deore Rear Derailleur Shimano Deore XT Crank Shimano M542, 44/32/22 Cassette SRAM PG-950 11-34, 9 speed Pedals n/a Components Saddle Bontrager Evoke 1 Seat Post Bontrager, 31.6mm, 20mm offset Handlebars Bontrager Low Riser, 31.8mm, 25mm rise, 9 degree sweep Stem Bontrager SSR, 31.8mm Headset 1-1/8" threadless, semi-integrated, semi-cartridge bearings Brakeset Avid Elixir 3 hydraulic disc brakes
Cannondale f1
- Frame Flash alloy SAVE BB30 and 1.5” HeadShok head tube
- Fork Lefty Speed alloy PBR and Solo Air OPI
- Rear Shock n/a
- Rims Mavic XM317,32 hole
- Hubs Cannondale Lefty SL & SRAM X-9
- Spokes DT Swiss Competition
- Tires Schwalbe Racing Ralph PaceStar 2.1”
- Pedals n/a
- Crank FSA Afterburner 386 BB30 42/27t
- BottomBracket BB30 included crank
- Chain KMC X10SL CP
- Rear Cogs SHIMANO SLX 11-36 10-speed
- Front Derailleur Shimano SLX
- Rear Derailleur SRAM X-9 carbon
- Shifters SRAM X-9
- Handlebars Cannondale C2 “zero rise”
- Stem Cannondale OPI adjustable stem/steerer 3D forged
- Headset Cannondale Si HeadShok
- Brakes Avid Elixir R
- Brakelevers Avid Elixir R
- Saddle Cannondale Stage crmo rails
- Seat Post Cannondale C2 27.2 mm 17 mm offset
- Grips Cannondale LE SuperLight II lock-on
