atenção aos mupgrades para a versão 3.2
pois há alguns bugs... que podem danificar o GPS --- DEIXA DE SE PODER LIGAR
https://forums.garmin.com/showthread.php?t=9901
SOLUÇÃO:
Thank you for contacting Garmin Europe.
Following on from our earlier conversation, please follow the below instructions to resolve the issue.
1. Download and install WebUpdater from the Garmin website here:
http://www8.garmin.com/support/colle...t=999-99999-27
2. Download the archive attached and extract the region file (file type
.rgn).
3. Open the directory into which WebUpdater was installed so that you
can see the WebUpdater executable.
4. Drag the region file (extracted previously) onto the executable file
WebUpdater. This will start the WebUpdater program and instruct it to load the indicated region file.
5. Before you press 'Next' on the WebUpdater program's main window,
attach your 705 to the computer via USB cable.
6. While holding up on the control stick of the 705, press and release
both the 'lap' and 'mode' buttons simultaneously. Do not release the control stick.
7. Immediately press the 'Next' button on the WebUpdater program's main
window.
8. The WebUpdater program will attempt to find the 705. As soon as the
unit is found, immediately press the 'Next' button in the WebUpdater program.
9. At this point the WebUpdater program should perform the update and
the program should issue the message 'Your Garmin device has been updated.' Release the control stick and leave the USB cable connected while the 705 executes its initialization procedure. This may take up to one minute, and the screen will be blank during this time. The 705 should restart automatically.
At this point, all user settings will be cleared and will need to be re-entered.
Please help us improve the service we offer you by taking our Customer Support survey. Please click the following link -
http://www.surveymonkey.com/s/GarminSupportSurvey
If there is anything else I can help you with then please let me know.
Alternatively you can search for a solution here:
http://www.garmin.co.uk/support
Kind regards,
Matthew Morley
Garmin Europe
https://forums.garmin.com//attachment.php?attachmentid=3015&d=1279979764
