Boas amigos,
Estou indeciso entre comprar uma MERIDA MATTS 40D 2014 e uma CUBE ANALOG 2011.
Specs da CUBE:
Product Type: Hardtail Mountain Bike
Model: 2011
Series: Cube Analog
Type: Mens Bike
Wheel Size: 26 inch
Frame Material: 7005 Aluminium
Gear System: With Derailleur
Number of Gears: 27
Rear Derailleur: Shimano SLX
Suspension Fork: yes
Fork: Suntour XCM
Braking System: Hydraulic Disc Brake
Brakes: Hayes Stroker Ryde
Weight: 13.5 kg
Bike Frame Size (inch): 14.0, 16.0, 20.0, 22.0, 18.0 inch
Headset: FSA No.10
Hub Dynamo: no
Adjustable Stem: no
Handlebars: Easton EA30, Low Riser
Stem: Easton EA30
Front Derailleur: Shimano Alivio
Front Chain Wheel Teeth: 44/32/22
Crankset: Shimano FC-M430
Rims: RFR AX24
Tyres: Schwalbe Smart Sam
Saddle: Scape Active 7
Specs da MERIDA:
Qual a melhor? Se for pelo ano compensa a MERIDA porque é mais recente e tem garantia e isso, mas em termos de componentes e qualidade e fiabilidade?
Obgd
Specs da CUBE:
Model: 2011
Series: Cube Analog
Type: Mens Bike
Wheel Size: 26 inch
Number of Gears: 27
Fork: Suntour XCM
Weight: 13.5 kg
Headset: FSA No.10
Hub Dynamo: no
Adjustable Stem: no
Stem: Easton EA30
Rims: RFR AX24
Specs da MERIDA:
COLORS | matt anthracite, blue, white |
FRAME SIZES | 14.5" 16" 18" 20" 22" 24" |
FRAME NAME | Matts Speed-D |
FORK | SR Suntour 26 XCT MLO 100 |
DERAILLEUR FRONT | Shimano M370 |
DERAILLEUR REAR | Shimano Altus 9 |
SHIFTER FRONT | Shimano Altus Rapidfire |
SHIFTER REAR | Shimano Altus Rapidfire |
BRAKE LEVER | attached |
BRAKE FRONT | ProMax DSK Hydraulic 160 mm |
BRAKE REAR | ProMax DSK Hydraulic 160 mm |
CHAINWHEEL | SR Suntour XCM 44-32-22 CG |
CHAINGUARD | attached |
BBSET | Cartridge Bearing |
CHAIN | KMC Z99 9s |
HUB FRONT | Alloy Disc QR |
HUB REAR | Alloy Disc QR |
RIM | Merida Matts D |
FREEWHEEL | SunRace CS-M9 11-32 |
TIRES | Merida 2.1 / Merida 2.1 |
SPOKES | stainless silver |
HANDLEBAR STEM | Merida Comp OS 7° |
HANDLEBAR | Merida Comp OS 640 R25 |
HEADSET | EGG Steel-B |
SEAT POST | Merida Speed 27.2 mm |
SADDLE | Merida Pro SI-E |
PEDAL | XC Alloy |
WEIGHT | 13.90 kg |
Obgd
