Bullet HD
Bullet HDT2P are pleased to offer the worlds first wearable action camera with a 12.0 Mega Pixel camera.
Weighing virtually nothing, its sleek design makes its one of the smallest HD action cameras on the market.
The Bullet HD can be mounted on your goggles, helmet, handlebars, vehicle or any flat surface you can think of.
It's aluminium armoured body is water, vibration and shockproof. So even the toughest situation and severest weather can't stop your recording.
With 2 rechargeable batteries offering 5 hours of recording time, you will never miss the unmissable again!
Features
The Bullet HD action camera with its fisheye lens, strikes the perfect balance in capturing the entire scene without distorting the video, just recording in picture perfect quality.
The recording couldn't be simpler. With only one button control to operate both video recording and stills, the Bullet HD records in HD straight to the MicroSD memory card, which can then transfered to your computer by the USB lead in a matter of seconds.
The Bullet supports MicroSD cards up to 32GB. Video format AVI-1GB/10mins. Iarge format JPEG.
With our full series of customised mounts you can record anywhere, anytime. The camera can be easily mounted to your handlebars, goggles, helmet, fairing or any flat surface.
Forget buying throw away batteries...The BulletHD comes with TWO rechargable lithium batteries, with a combined power of 5 hours continueous recording time.
The aluminum armoured body is not only strong and sturdy. It is also capable of recording in all weather conditions, and is both shock and vibation proof. It can withstand dust, dirt,mud, snow and can even be fully submerged underwater, so nothing prevents your recording oppourtunity.
Bullet HD
£164.99 Add to Cart
Bullet HD side on
Bullet on handlebars
Bullet on helmet
Tech Specs
Image sensor: High Sensitivity CMOS Image Sensor
Photo resolution: 12.0 Mega Pixel
Image format: JPEG
Video resolution: 1280 x 720P (HD)
Video format: AVI
Frames per second: 30 FPS
Recording angle: 170°
Microphone: Built-in
Battery: 850mAh rechargeable lithium
Battery life: Video recording up to 2 hours
Battery charge time: 2.5 to 3 Hours
Memory: MicroSD up to 32 GB
Connectivity: USB 2.0
Dimensions: 90mm (L) x 30mm (Dia)
Weight: Camera fully loaded with battery & memory card - 99g
Contents
360 Degree Mount for Handlebars/Vented Helmet
Strap Mount for Non-vented Helmet/Goggles
Camcorder Mount Adapter
Universal Mount Adapter
Adjustable Silicon Straps
Magic Tape
Battery 2 pieces
Hand Safety Strap
3M Sticker 2 pieces
Charger
USB Cable
User Manual
Travel Case
Silicon Grease
Rubber O-ring
Bullet HD
£164.99
